Help - Dino won't start!
Madeche
Dino: Ferrari Dino 246 GT
Post by Madeche »
hi all,
my 1967 Dino Spider 2L won't start. It has been recently fully serviced including a new battery. It was working fine last week now it does not start. I put the key in the ignition and turn it and nothing happens. I can hear the fuel pump (I think) but the engine does not even turn over. Any ideas? Starter? If so, what can I do? I am not mechanically sophisticated as you may have guessed :) Thanks for your help.
Re: Help - Dino won't start!
Check the battery. Then check if the starter gets power.
Argonaut
Post by Argonaut »
I guess, Tobi is right. My Dinos do have the same problem every now and then... Trying it a few times the starter feels convinced to operate again. But.. could also be an issue within the ignition switch.
Madeche
Post by Madeche »
Hi guys, new battery fixed it :) thanks for your help
