Fiat Dino fuel delivery
Jon
Post by Jon »
Hello I have a 2.4 coupe with original fuel pump which intermittently got stuck and needed a little tap to get it going... I recently changed to Facet red top fuel pump and nice pressure regulator from Superformance... But due to fuel delivery problems, I had to update to a red top Facet with slightly higher specs than Superformance Redtop... I am getting good flow to the pressure regulator and bowl is filling up better but still bogged down if I tried to let out the clutch... Carbs were cleaned out and prior to fuel pump change I did not have these issues... Any suggestions? Thanks much...
Re: Fiat Dino fuel delivery
Maybe fuel pressure changed compared to the old configuration?
In that case the needle valves in the carburettor might need some attention or re-adjustment because of changed float level.
Barnfind
Post by Barnfind »
Start the fuel pump, and get a look inside the carbs. If any is dripping inside , then the pressure is too high.
