Red warning light on tach
jkernxx1
Post by jkernxx1 »
Working on restoring a newly acquired 1967 Fiat Dino 2000 Coupe. There is a red warning light that is persistently on in the tachometer. Manual says it is a battery charging warning light, but the battery is charging. Appreciate any help in sorting out the problem.
JKernxx1
1967 Fiat Dino 2000 Couoe
1969 E-Type Jaguar Couoe
agnatus
Re: Red warning light on tach
Post by agnatus »
Perhaps the relay that controls the charging indicator light is faulty, or some of the connections aren't right.
I don't have a wiring diagram for the Fiat Dino 2000 Coupe handy, but the relay switches off the charging indicator light when the alternator is supplying approximately 14V.
In the wiring diagram for the Fiat Dino 2000 Spider, relay 37 switches the charging indicator light (50).
Fiat_Dino_2000_Wiring_Diagram_Key.pdf
(438.88 KiB) Downloaded 68 times
Fiat_Dino_2000_Wiring_Diagram.pdf
(3.39 MiB) Downloaded 54 times
