ceramic coating on exhaust
ttc46
Post by ttc46 »
Hello,
To reduce the temperature under the motor hood and to avoid vapor-lock problem, I think that one solution is to make a ceramic coating on the exhaust,
like Zircotec in UK do.
https://www.zircotec.com/exhaust-coatings
Someone among you has already adopted this solution ?
If so, is it effective?
Have you another solution?
ttc46
Re: ceramic coating on exhaust
Post by ttc46 »
Hello,
After research, I found a supplier in France, who made me the 6 exhaust and the 3in1.
The result is very significant; I made a journey in Italy in June and I could see that the temperature under the motor hood was very lower than before,
especially after 2-3 hours journey and our feet were colder. :D
And this for a reasonable price (about 500€).
2dinos
Post by 2dinos »
I ceramic coated my exhaust and still experienced pretty annoying vapor lock on hot days. I think heat comes from engine soaking carbs. I set up a fuel return to move fuel as the later cars.
