I'm helping a buddy restore one of these gems. We are missing the throttle linkage component, which rotates and is supported by two plastic spherical bearings (one mounted to the firewall, the other to the back of the engine). I may need to fab this up.
Two requests:
A. Any knowledge of a source for one of these? I researched the usual Dino parts sources. This is a tough one - even by Dino standards.
OR
B. Can someone give me some dimensions? I figure it is 12mm Ø torque tube (from the bearing bores), and approximately 16" long.
I could use some better numbers for:
1. The length?
2. Length of the "arms". I guesstimate about 3cm? From ball center to surface of 12mm torque tube
3. Angle between the arms? (From pics looks like ~ 15-30º?)
4. Distance between arms
And any other tech tidbits that come to mind. This will help the creation process. Many thanks!!
Dino 2400 Throttle Linkage
Re: Dino 2400 Throttle Linkage
Which items do you need? I probably have most of them. See attached picture.
BRGDS
Hans Jepsen, Denmark
BRGDS
Hi Hans,
Thank you for your reply. I put together a list of pieces we can't find (11 parts total)
1) 4177037, SHAFT
2) 4177038, LEVER (QTY 2)
3) 4177028, TIEROD
4) 10124311, SOCKET (QTY 2)
5) 4177040, WASHER
6) 4177041, SPRING
7) 10124775, SPRING (QTY 3)
This would be a great help if I did not have to make these.
Best regards,
Bruce
1) 4177037, SHAFT
3) 4177028, TIEROD
5) 4177040, WASHER
6) 4177041, SPRING
Best regards,
Bruce
Hi Bruce,
Do you have a e-mail. I want to forward some pictures to you.
BRGDS
Hans
BRGDS
Hans
