fiamm compressor and air horns
ronenya
Post by ronenya »
I have here an original set of Fiamm road master compressor and air horns. I attached to a battery, the compressor is working, but there came no sound...
send me a message for a price request
ronenya
Re: fiamm compressor and air horns
Post by ronenya »
The Price is 300ָ€
I am not sure if I get it right: it is not working and you want 300Euro?
croker
Post by croker »
Hi. Please private message me. Interested.
ronenya
Post by ronenya »
Hi, Sorry for not reacting, I was long out of the board.
@ThomasK, As a matter of fact the compressor is working, only it doesn't horn always, like it used to...
Thanks for @Tobi(admin) for recovering my old user name!
For more details call me to +4915120206012
ebrown5686
Post by ebrown5686 »
Hi Ronenya,
I was having trouble with mine, compressor working and hoses intact. I pulled off the trumpets, cleaned the inside of the trumpets and got some crud out of the bases. It still wouldn't work...but I discovered in my case they didn't work until I started rotating the trumpets up and down and found that when I got to a certain length, they would take off again! Something to do with the harmonics, just like a musical instrument I guess. Mine have been working fine now for a couple of years.
I can't promise it will work, but I did have some fun playing with them and you probably have nothing to lose. Good luck and hope this helps. It's great when they finally start bellowing again!
Ed Brown
Spider 2400 #1396
ronenya
Post by ronenya »
Hi Ed,
Thanks for the tips, I will just give it a try...
- ronen
jtperry8sf9
Post by jtperry8sf9 »
Ronen,
Be extremely careful to not over tighten the trumpets. You will damage the internal, very thin, brass shims which vibrate with the air pressure. Guess how I know! I managed to remake mine out of some very thin shim stock and they do work again.
Johnny Pergolizzi
San Diego, Ca.
ronenya
Post by ronenya »
Hi Johnny, thank you the issue was solved and the airhorns already sold!
