Beside the question regarding the intermittent mode in a different thread
I have a general problem with my wipers and I am really running out
of ideas why it doesn't work!
When I turn on the continuous mode (the intermittent doesn't work at all as you know)
the wipers start moving and then get stuck after some seconds.
This means that:
a) the engine's power is too low to move the wipers
or
b) that the mechanical resistance in the whole assembly
is too high for the engine.
I have done the following already:
1.) Disassembled, cleaned and greased the whole mechanism
including the flexible connection shaft. Everything moves now
without high resistance, so should be fine.
2.) Changed the wiper engine with a used one. This made
the wipers work for my first try. When I re adjusted the wipers
today the same problem as before occurred.
When I turn on the wipers without the wiper arms on the
windscreen it works absolutely fine! It also works when I lift
the wipers a little when they got stuck. This leads to
the assumption that the wiper arms are not correct (pressure on the
wind screen is too high) but this would be very strange as the whole
car is completely original.
I could cut the springs in the arms a little but I would like
to hear some other opinions before I do this. Does anybody
have a picture of original 2.4 litre wiper arms?
I have to say that I am getting very frustrated about this
Thanks for you help! Cheers
Bijan
