Starter motor removal
4cambob
Post by 4cambob »
Is it possible to remove the starter motor from the 2000 coupe without removing the exhaust manifolds first. Also I can't even see enough space to withdraw it out from underneath.
agnatus
Re: Starter motor removal
Post by agnatus »
On the Spider 2000, it worked without having to remove the exhaust manifolds;
I replaced the original Fiat starter motor with a Wasp unit.
It was a real fiddly job, but it worked!
I assume there’s no significant difference in the amount of space around the starter area between the Spider and the Coupé.
4cambob
Post by 4cambob »
Did you remove the starter motor upwards through the engine bay or from underneath.
