distributer conversion to optical pickup
Posted: Sun Oct 02, 2016 8:46 pm
Hi, just wanted to report that I decided to swap my working dinoplex and its coil for a luminition optical pickup with the bosch transistorise ignition setup. I had an issue with the points recently, where they had moved/displaced and shorted, leaving me temporarily stranded. I can't say if the fault was with the installation of the new points or their quality, but it wasn't fun.
For a full guide, visit dinoplex.org
I followed Adrian's advice to the letter and it worked right off the bat. I used the OS50 and FK 124 package. The latter's wheel is a bit loose, though, and the plate to hold the optical switch needs to be fabricated. I simply copied one of the points base plate, out of 5mm steel. You need the extra thickness to clear the timing wheel. Nothing special appart from that, it really is a simple installation that does take a bit of time. I found an old aluminum box that resembles one of the more recent dinoplexes to mount the Bosch chip. To adjust timing, I just followed the instructions that came with the car: with the no. 4 cylinder at TDC, make sure the timing wheel is positioned so that you can generate a spark when the distributer is turned from full left to full right. Cold starting was improved over the dinoplex, as wall the idle when cold. In fact, I even had to turn back the idle a little.
The good thing is that you can always go back to the points and dinoplex later on.
So, thank you Adrian!
