I'm finally ready to start the engine on my 2.0 coupe after a complete rebuild, but want to ensure adequate oil pressure first. Can the feed into the oil filter be used to prime the oil pump? or is there a better way. Clearly the first cranks will be with the ignition disable and the plugs out... any other recommendations.
thanks
Rick
Portland Oregon
Engine start up process
Re: Engine start up process
Hi Rick,
That's very exciting , the only help I can offer you is to forward my mechanic's email address…he would definitely have the answers you're looking for should you get stuck.
John
John
As you say, crank it over with the plugs out until oil pressure is showing.
Your engine builder should have used an assembly lubricant on the cams and bearings and this should still be present.
I might be tempted to put a shot or two of oil down the bores.
Don't forget to check the oil level once you've cranked it for a bit.
I understand what you mean with priming the oil pump. I think hardly anyone does that and it will most likely suck up oil after some time but I always fill the pump from the oil filter feed side and turn the engine in counter direction to be sure the pump and suction tube to the sump is full with oil. It might not be necessary but it won't do any harm.
Hi Rick, The reason that people spin engines without ignition after a rebuild is to ensure that the oil pump (and its pressure side line connections) are working properly, prior to starting the engine. Pumping oil into an engine manually prior to spinning it doesn't really have much effect on anything, especially if the engine has been assembled with proper assembly lube, or grease, or oil. Many brand new engines have been burned up because of mis-assembled check valves and new oil pumps not lining up with oil ports. (This comment is general and not specific to Dino engines). It is definitely a good idea to pull the plugs and spin the engine, while checking for oil pressure to confirm that your oil pump is working before you risk running a new engine. Once you have determined that the engine makes oil pressure then you can add ignition and run it. Tribologists will tell you that the working pressure in a plain bearing develops from RPM, not from the pump pressure. The pump is only there to supply and circulate the oil. All oil pumps need to be self-priming in order to work properly so manual priming doesn't test that the pump is working properly.
