Door hinge bushes
Posted: Fri Jan 29, 2016 10:39 pm
by Stefan2000
Just had some bushes made for the door hinges, if anyone is in need I can have them refabricated.
Re: Door hinge bushes
Posted: Wed Jul 06, 2016 1:13 am
by MaseratiSD
Do you have any of your door hinge bushings handy? I'm trying to get my car to Monterey this year and the door hinges are the last bits I need...
MaseratiSD
Posted: Tue Sep 27, 2016 3:26 am
by Brent
Hi Stefan,
I have a 2400 Dino Coupe with sagging hinges. Is it easy to have these re-fabricated or are you able to point me towards someone who can supply them?
Any help you can provide would be very much appreciated.
Regards,
Brent
New Zealand
Posted: Thu Sep 29, 2016 12:04 am
by fdus172
I was able to get door bushings and pins for my 2.0 coupe from Fiat Plus in the US. The fit was terrific..
http://www.fiatplus.com/
Rick Wohleber
Portland Or
Posted: Sun Oct 02, 2016 5:27 am
by GaryS
baahhh plastic. I used 'used' valve guides (dino of course) and turned down the OD (for a very mild friction fit) and trimmed to length. ID is 8mm as is doorpin - and valve stem. For upper shoulder I used a washer. Felt like an idiot savant when I came up with that one! (further dividend the valve guide is a naturally lubricating alloy) Even a worn guide (substantial stem to guide wobble) will provide an exceptionally precise and extremely long lasting solution for a better hinge bushing. Also worth mentioning, the quality of the doorpins Bertone used (1967) is very high. No corrosions, discolorations, or galling of the splines upon inspection after being pressed out.
Gary
Posted: Tue Oct 04, 2016 12:13 pm
by Stefan2000
I do not have them right now but I could share the dimensions if you want to have them remanufactured at a machine shop at your place.
Posted: Thu Dec 21, 2017 8:57 pm
by johnharrill
Sent mine off the guy on Ebay (Really!) and he did a great job. Bores out the pins and inserts bronze bushings
https://www.ebay.com/usr/fast-action?_t ... 7675.l2559
