Engine removal from below
Posted: Fri May 08, 2015 2:44 am
by mostromilano
Folks
A very nice thread (17 year Dino restoration) shows engine removal from the bottom. I have access to a very nice 2-post lift (but not a cherry picker style hoist) and am curious if anyone else has removed their engine/trans from below by lifting the body off. It looks like the lower control arms and mounts come with it as an assembly (engine, trans, subframe w/ lower arms and ball joints).
Feedback welcome, and if none - guess I'll have a go at it myself when the time comes.
Re: Engine removal from below
Posted: Sun May 10, 2015 12:52 am
by ThomasK
I have Pulled my Engine out and in From below. Works very good with my pit and a crane on the ceiling. Lower Arms and all steering Arms have to be removed as well as the exhaust System and the Part that sits unter the Engine where the lower Controller Arms are connected to (dont know the englisch Name for it) and the stabiliser bar. Works Pretty well.
Posted: Sun May 10, 2015 7:43 am
by ThomasK
Here is a picture....
Posted: Sun May 10, 2015 12:24 pm
by Guzzi
Having done it recently the easiest way is to remove the engine from above. The most difficult part is removing the top two bolts on the bell housing but suitable flexible socket extensions will do the job. Solo, it took me two hours. It should be a simple matter to rent an engine lifter?
Posted: Thu May 21, 2015 3:51 pm
by mostromilano
Very helpful, thanks all.
Great looking Coupe, Thomas.
Posted: Sun Jun 07, 2015 3:56 pm
by blair_g
mostromilano I have a question regarding trans. strategist95@yahoo.com
Posted: Sat Jul 11, 2015 5:14 am
by mostromilano
Guzzi wrote:Having done it recently the easiest way is to remove the engine from above. The most difficult part is removing the top two bolts on the bell housing but suitable flexible socket extensions will do the job. Solo, it took me two hours. It should be a simple matter to rent an engine lifter?
Well, I decided to do it from the top. It's simple so far - but I'm tight on space for exhaust header extraction. Can the motor/trans assembly be pulled with the headers in place?
Posted: Sun Jul 12, 2015 1:16 am
by Guzzi
No, headers have to come off. I made the same error but fortunately removal isn't that difficult provided they're not rusted into the collector
Posted: Sun Jul 12, 2015 5:34 am
by mostromilano
Thanks. Engine out now :)
