Page 1 of 2
				2400 Coupe battery box
				Posted: Fri Mar 13, 2015 11:23 pm
				by doublegarage
				Could someone who has a 2400 Coupe maybe take some pictures of the cover or box that'sover the battery in the boot/trunk, please?
Mine is completely missing, I might try to make one but have never seen one close up.
				Re: 2400 Coupe battery box
				Posted: Fri Mar 27, 2015 7:32 am
				by doublegarage
				please?
s'il vous plait?
				Posted: Fri Mar 27, 2015 11:41 am
				by AndyC
				Richard,
I'll post some pictures this weekend, if you can wait a day or two longer!
				Posted: Fri Mar 27, 2015 5:32 pm
				by doublegarage
				Thanks Andy - yes I can definitely wait a few days.
thank you!
				Posted: Fri Mar 27, 2015 6:40 pm
				Hi Richard,
Maybe these pics help. Please note that the units are not imperial and the crack is not original
Let me know if you need more details.
Regards,
				Posted: Fri Mar 27, 2015 11:44 pm
				by doublegarage
				Thanks Tobi, that's perfect.
Unless anyone has a spare one of these I could buy, I'll try to make one form plywood and carpet it.   Hope that's okay with everyone
Also, on the left side of the boot, around the fuel filler door and pipes, there is a missing piece of the floor - i.e., there is the box that contains the spare tire, but then a big hole before you get to the left rear wing.  Should there be another cover there? To stop things falling down below the fuel filler?  Maybe I should take a picture, not easy to describe.
Cheers,
				Posted: Sun Mar 29, 2015 3:00 pm
				by AndyC
				Some more pics to add to Tobi's. The battery box and spare wheel cover were both missing from my car when I bought it, so I made them from marine ply after a couple of attempts with cardboard templates. Even after I obtained the correct item on Ebay I've left my home made one fitted, as it looked tidier once carpeted. Also fitted adaptor for my CTEK charger which constantly indicates battery state, and just plug in to charge.
				Posted: Wed Apr 08, 2015 6:04 am
				by doublegarage
				Andy,
sorry, I'm slow to reply - thanks for your pictures - your plywood cover is what I shall build, I think - and good idea to have a socket for your battery-charger on the outside.   Looks great carpeted, very nice.
				Posted: Wed Apr 08, 2015 6:44 am
				Hi Richard,
If you're already installing a charger socket, think about installing a circuit breaker as well. It might be useful if you don't want to let your car under voltage when not driving.
Regards,
				Posted: Tue Mar 23, 2021 3:15 am
				by johnharrill
				With the cover over the battery, where does the negative cable enter the box?
