Re: Candle in the wind...
Posted: Sun Nov 13, 2022 1:27 am
Hi all
Don`t forgett the ground wire!
To check voltage drop effect easily, I make 2 jumper wires (with 10 amp fuse) and drive the actual car against a wall/ garage door.
Turn on the light (when egine is running at increased idle), and insert the jumperwire from battery -/ ground to bulb -/ ground, and simultaneously look at the light intensity on the wall.
Then I do the same with the +/ power side, jump a wire from battery +/ positive to the bulb +/ positive, and take a look at the light intensity at the wall.
This gives you a quick view on what a relay conversion job will do for the light intensity on your car (But relay`s are only on the +/ positive side, so don`t forgett the -/ ground )
