Lower compression cylinder
Posted: Tue Jul 19, 2022 2:55 pm
I have had some issues with one piston from my Dino 2400 Coupe’s engine. Some external piece went inside / probably when vendor changed the carburators - we managed to remove it and the engine now works well. But the cylinder is a bit damaged with compression higher than before but not top.
The advice from my mechanic is to use the Dino and enjoy it until we stumble some new issues and then consider opening engine and change what need to be changed.
What’s the aficionado’s views on that approach?
F
F
