Pressure valve on the fuel filter
Posted: Tue Apr 15, 2014 10:05 pm
by 1des3mousquettaires
Hello guys,
I'm actually looking for some info about the pressure valves on the fuel filter of my 2.0 Coupé.
There is a screw on top of the filter with which one can regulate the fuel pressure,but I can't find anything about it's function in the "Specifications and features" manual.
Can anybody help?
Thank's a lot in advance!
Dirk
#2813
Re: Pressure valve on the fuel filter
Posted: Fri Apr 18, 2014 8:46 pm
by ThomasK
The pressure regulator is for: regulating the fuel pressure - by turning the screw.
Therefore you need to have an (temporarely9 installed) instrument to show you the current fuel pressure, to be put in the fuel line after the pressure regulator.
In the manual the fuel pressure is said to be 0,23 psi, so you should turn the screw until this pressure is reached.
KR, Thomas
Posted: Fri Sep 09, 2016 8:00 pm
by Xgrau
ThomasK wrote:The pressure regulator is for: regulating the fuel pressure - by turning the screw.
KR, Thomas
I read the text above and I think the correct pressure is 0,23 Bar (not psi)
KR, Xgrau
Posted: Fri Sep 09, 2016 8:51 pm
by ThomasK
yes, correct, sorry for my fault.
