2400 Rocker Trim
Re: 2400 Rocker Trim
Post by Fanalone »
Dinoparts have reproduction of the rocker trim to the 2400 Coupe in stock: http://www.dinoparts.eu/EN/fiat-coupe-s ... coupe.html
Jos_2400
Post by Jos_2400 »
The small pieces, as seen on previous posts, are original and should be on the Dino to finish off the trim in both wheel arches.
Most of them disappeared by being corroded or after a "restoration" on the sills.
Ids Bierma in the Netherlands has made very good replica's of the small pieces.
Ask him: https://www.facebook.com/ids.bierma
Regards,
Jos
To add to this post, I can add that the trim for the 2400 spider was a little shorter than that of the coupe :)
