Page 2 of 3
Re: Oils.
Posted: Fri Mar 20, 2015 2:08 am
by Barnfind
Thanks for your replies.
Data sheet downloaded.
GL4. I have read about GL5 and the brass synchros problem.
Regards..
Re: Oils.
Posted: Fri Mar 20, 2015 2:19 am
by doublegarage
GL-4/GL-5
yes from what I understand it's worse for cars that sit unused for long periods of time - but either way, GL-4 seems like the way to go to be on the safe side.
Re: Oils.
Posted: Fri Mar 20, 2015 5:00 pm
by Barnfind
Got today Petronas GL4. Seems that actually Petronas distributes Tutela.
Re: Oils.
Posted: Thu Mar 26, 2015 7:39 am
by Barnfind
What about RedLine for you guys un US? It has been widely used in Ferraris..
Re: Oils.
Posted: Wed Apr 17, 2019 7:18 pm
by vlad
How much oil is required?
(For the 2.4 diff)
Re: Oils.
Posted: Wed Apr 17, 2019 7:23 pm
vlad wrote: ↑Wed Apr 17, 2019 7:18 pm How much oil is required?
(For the 2.4 diff)
Should be around 3 liters W90/M-DA. Better drain it and refill it to the level opening.
Re: Oils.
Posted: Wed Apr 17, 2019 7:33 pm
by vlad
Thanks it was drained as part of a rebuild, new drive shaft bearings and oil seals + pinion bearings
Re: Oils.
Posted: Wed Apr 17, 2019 8:14 pm
Try to get the Tutela W90/M-DA. You might experience problems with other oils even if they have the same specs. It's still available from Fiat or Iveco dealers.
Re: Oils.
Posted: Sun May 05, 2019 12:59 pm
by botond1222
Dear all,
any suggestion for Oil Filter and engine oil please?
Thank you!
Botond
Re: Oils.
Posted: Sun May 05, 2019 4:26 pm
I use the UFI 23.162.02 oil filter. It is important that it has a riser inside that prevents complete drainage.
Regular 20W-50 mineral oil is perfect for the Dino.
