Body shell question #000665
In the attached photo( body is upside down in a rotisserie) the body from engine compartment to transmission tunnel on the right side of the photo and car the right side up, you can see the sheet metal is bent over.
Is this done at the factory for starter clearance, or damaged probably buy the bellowing by someone trying to take the engine out up thru the engine room instead of dropping it down
Any insight would be appreciated
Re: Body shell question #000665
Sorry photo didn’t attach
Note fold on r/s of bellhousing.
