Hi, Having an issue with power window cables on a 67 coupe. For some reason after the cables are installed the cable gets tangled at the motor after running up and down a half a dozen times or so. Has anyone come across this issue? Is there a specific way to run and tension the cable to avoid issues? Any help appreciated.
Alex
Electric Window cable problems
alexjordan
