Has anyone been able to order rear shocks recently? I'm wondering if someone has them on the shelf. I have the suspension apart and I want to change the shocks before I put it all back together.
Best Regards,
Philip
Rear Shocks Available?
Re: Rear Shocks Available?
I don't remember if superformance stocks them, or has gone out of stock. It is worth to have a look.
Dinoparts used to sell koni inserts. I don't know if MrFiat sells them also.
We recently bought (for a 2L Spider) what we were told was the last set of Konis available. They're batch made so there could be a delay. A good Koni agent should be able to either track some down or build you a set from a sample. If you have the original OEM units they MAY be able to be rebuilt if you can find the right seals. If you have worn out Konis they can definitely be rebuilt
Peter
Peter
The big deal is with 2400 rear, as they are very specific. Front can be fitted with anything for 132, 125, Argenta, as part number is the same (and I know without any doubt they fit)Guzzi wrote:We recently bought (for a 2L Spider) what we were told was the last set of Konis available. They're batch made so there could be a delay. A good Koni agent should be able to either track some down or build you a set from a sample. If you have the original OEM units they MAY be able to be rebuilt if you can find the right seals. If you have worn out Konis they can definitely be rebuilt
Peter
I sent my original 2400 front and rear shocks back to KONI to be rebuilt.
