Controlling your engine Temp from Dash
Post by Dario »
Hi everyone,
I am wondering if anyone else sees this: When I turn on the headlights, the Temp gage goes from 90°C to 95°C. In fact, I can adjust the T° by turning the rheostat for the interior dashboard lights! When it's off, I go back to 90°C, at full brightness, I get 95°C.
I suspect the usual faulty ground connection somewhere, and was wondering if someone had seen this before and knows where to look for the ground connection to the chassis. I really don't want to take out the dash, so I'm hoping I can reach up and wiggle a wire somewhere :)
fdus172
Re: Controlling your engine Temp from Dash
Post by fdus172 »
Not sure about the Spyder, but If you have a coupe - you can easily remove the front part of the dash. Four allen screws and that section lifts out ( there doesn't seem to be anything tying in the air vents). With that part out, you have full and easy access to all the gauge wiring.
Rick Wohleber
Dublin Ohio
Post by Dario »
Wow, that's great. I have the 2.4 Coupe, which has a squarish dash with the instruments. Do you mean that this comes off easily? I never knew...
fdus172
Post by fdus172 »
The 2.0 coupe has a 6 inch forward section the length of the dash - this is the part I was referring... looks like the 2.4 doesn't have this 'feature'
Rick
fdus172
Post by fdus172 »
But now that I look at the 2.4 body parts manual - it does appear that the top of the dash would come off without too much trouble - perhaps the other 2.4 guys would know.
Rick
