Wanted - Weber 40 DCNF accelerator pump cover screw/post
1967 FIAT Dino coupe, 40 DCNF 12 carbs. On the accelerator pump cover there are 4 fasteners. 3 fasteners are regular screws. The 4th fastener is a threaded rod with a 7 mm hex nut incorporated into the shaft of the fastener. On the end of the fastener there is a post which holds a spring which is connected to the throttle lever bell crank. I am looking for that special 4th fastener. Does anyone have one for sale and/or know where I can find one? Thanks, Ben. bhiggins2@aol.com
