Fuel Door Flap.
johnharrill
Fuel Door Flap.
Post by johnharrill »
The P.O. of the 1967 Coupe I am working on had a fuel door, however I don't think it is from a Dino coupe.
There is a hole for a (chrome) tab, which I do not think is stock. Also, there is a bracket/lever that looks to be for the attachment of a spring to close the door.
I've looked for photos and in the parts book, but details are sparse. Is this the correct door?
Re: Fuel Door Flap.
Hi, maybe helps this picture from my 2400 Coupe. As the door had no lock some placed a lock later into it to prevent petrol being stolen. Looks as such a thing in your case. KR Thomas
Fuel Door
Fuel Door
Re: Fuel Door Flap.
I somewhere have a fuel door as a spare without a hole for a lock. If I find it I post a picture.
johnharrill
Re: Fuel Door Flap.
johnharrill
Re: Fuel Door Flap.
Is there a spring that assists the door?
If so, where does it attach to the body?
4cambob
Re: Fuel Door Flap.
Post by 4cambob »
There should be a spring , which fits on the lower bracket. I will try and get a photo if possible.
Re: Fuel Door Flap.
This is the spring which closes the flap.
johnharrill
Re: Fuel Door Flap.
Where can I get one?
The usual sources do not have it.
Re: Fuel Door Flap.
Post by Scalino »
I can’t imagine these weren’t used in other Fiats of the era, so I would have a look at 124 part suppliers.
johnharrill
Re: Fuel Door Flap.
124 Spiders (PinninFarina) uses a different system. The 124 Sport Coupe (Bertone) - looked around for the spring but no luck.
