Oil pressure gauge link to fuel pump
Beanderb4
Post by Beanderb4 »
Hi folks,
I have seen some posts relating to oil pressure and the cut off circuit for the fuel pump where oil pressure is too low. I came across the following technical drawing which should help anyone that is trying to understand the circui / wiring.
I hope this helps someone. It certainly made it clear for me.
Paul
Re: Oil pressure gauge link to fuel pump
The reduced circuit diagram here might help as well: http://www.dino-register-deutschland.de ... f=20&t=534
And also this discussion: viewtopic.php?f=3&t=35&start=60
Beanderb4
Post by Beanderb4 »
Thanks Toni. That wiring diagram is excellent.
I did not come across that wiring diagram before?
Are there more wiring diagrams like that available in color?
paul
Yes, I made a few. They are here: viewforum.php?f=19
